I have a old style 289/302 bellhousing with the t-5 conversion plate attached and the clutch fork.
All in excellent condition $100 plus shipping.
I have pix on request.
I think you still need a modified cross member and a different drive shaft.
Not sure but I think you also need some modification to the clutch linkage and maybe a different starter and flywheel.
Erials is right, you will need the cross member.
I was able to use my same driveshaft without modification , but you may need a new yoke, some fit some don't. I was able to use a V8 4 spped yoke with my t-5.
If you are changing from an automatic you may need a new starter and other modifications.
I'm not certain what'all you will need if you have an automatic since I have not swapped from an auto.
