For $1000 you might as well find a 6 bolt engine.Woodchuck's recommendation of doing the T5 fulcrum relocation is probably the cheapest, but you'll need to drill and tap the cast iron bellhousing. Not really difficult.
Your other option is a Quicktime Bellhousing.
Quick Time Bellhousing Ford 5-bolt SB Ford to T5/TKO TKX Cable release/ RM-6067 - Modern Driveline
Quick Time Bellhousing RM-6067 Fits: Ford 5 bolt SB Ford to T5/TKO TKX Cable release Features Whatever engine or transmission you have – hard-to-find and even one-of-a-kind applications are a reality with Quick Time Twice the strength of other steel bellhousings, with pinpoint dimensional...www.moderndriveline.com
Let me know if you want to buy a lightly used adapter plate. When I did my conversion I went with the adapter plate but might swap it for a bell housing at some point.Alright folks, need to get some advice. Forgive me if this doesn’t make sense but I’m tired.
I finally gathered all the parts to convert my 65 coupe with a 289 from a C4 to a T-5 with a 3:50 gear and Holman Moody hi-po cam (hydraulic lifters). I also bought the Modern Driveline cable setup. I pulled the engine and transmission only to discover I have a 5 bolt 289.
From what I understand, my only option is to look for a 5 bolt 3 or 4 speed bell housing and adapter plate to use said bell housing with the T-5 and then use a Z-bar instead of the cable clutch. I believe someone makes an adapter bell housing but it’s close to $900 which isn’t an option.
Am I missing anything?
Why? MDL makes a 5-bolt (narrow pattern) bellhousing adapter plate....Woodchuck's recommendation of doing the T5 fulcrum relocation is probably the cheapest, but you'll need to drill and tap the cast iron bellhousing. Not really difficult.
Are you talking about the plate that goes between the bellhousing and transmission or do they make a plate that goes between the block and the bellhousing?Why? MDL makes a 5-bolt (narrow pattern) bellhousing adapter plate....
Not to Steal this question of Bart, I did the T5 to 5 bolt. I too, needed, a 5 bolt manual bell, the pedal box etc. I stuck with the “Z” bar clutch actuating system for simplicity. I purchased n adapter plate to mate the transmission to the bell. I recall the adapter being between 150-200. But this in in 2010.Are you talking about the plate that goes between the bellhousing and transmission or do they make a plate that goes between the block and the bellhousing?
MDL has adapter plates for between the bellhousing and transmission for both the narrow pattern (5-bolt bell) and wide pattern (6-bolt bell).Are you talking about the plate that goes between the bellhousing and transmission or do they make a plate that goes between the block and the bellhousing?
K. I'm kinda confused. I agreed with you on my first post of using an early bell with the relocated fulcrum so OP could use the cable kit he already has. That would be the easiest, assuming he's capable of relocating the fulcrum.MDL has adapter plates for between the bellhousing and transmission for both the narrow pattern (5-bolt bell) and wide pattern (6-bolt bell).
I’ll sent you a message.Let me know if you want to buy a lightly used adapter plate. When I did my conversion I went with the adapter plate but might swap it for a bell housing at some point.
Yes, although I would drill and tap to accept a TimeSert steel threaded insert, Loc-Tited in place.Is the bell housing thick enough to drill and tap to accept the ball pivot?
If I recall, (15 years ago) that's the same vendor, whose adapter I used. Still in service using 5 bolt bell.View attachment 878464 So there it is! California Pony Cars adapter plate fits great. Had to make the modifications recommended in the instructions. Now I need to add an adjustable pivot (the hole will go through the adapter as well so there will be plenty of strength to cut threads) and widen the hole for the clutch fork.
Also I have to create a bracket for the clutch cable on the side of the bellhousing. Anyone have any suggestions on this part?
Ok, I looked at the cable system and didn't feel its use was in keeping with the "classic' look I was seeking. Also, was not impressed with the reports of how they tend to get burned with routing in and around the header.The hydraulic systems readily available now were not that well known then. Definitely, did not like the Mcloid system that's on the nose/shank of the input shaft. Therefore, I went with a heavy duty and rollerized version of the "Z" bar and have never regretted it.Did you use a Z-bar or cable setup? If cable, how did you make the cable bracket on the side to emulate the T5?
