Hello to all. I have a 66 notchback that I am finally beginning to work on. I have owned it since 02/03. I am converting the C4 to the T5 with a 306 roller. I just purchased a t5 for $200. It was out of a 86 asc mclaren with 64k. The seller couldn't get the number off the tag. I met the seller and decided to purchase the t5. Once home, I took a wire brush and cleaned the tag and was able to read the numbers. It was a 1352-126, 85 Capri WC 5.0. 3.335 1st, 1.93 2nd, 1.29 3rd, 1.00 4th, and .80 5th.
There is not much info that I could find about the unit because of the 3.35 and .80 5th. Any insight would be helpful.
What gearing would you recommend for the 8 in? Would I be better of with a 3.40 or 3.55?
The engine is a 306 roller with a xe274hr cam, edelbrock air gap intake, holley 650dp and aluminum heads(im looking at a set of brodix st 5.0r).
Thanks in advance
Thanks in advance
