When putting a T5 in a 65, does the shifter come through the original hole in the tunnel, or do you have to relocate the hole?
N
It will come up near the stock hole. I trimmed a little bit of the floor so I had access to the shifter bolts. If you bolt the shifter on before you install the tranny you can probably avoid this. HTH
I had to trim mine. No big deal and it did make removing and installing the shifter much easier.
I found my old T-5 came up through the original shifter hole, but slightly to the right. A little trimming was in order.
