From the net- The factory negative coil wire should be Dark Green with a Yellow stripe wire.
Your coild has two terminals, one is +12V from the ingnition switch ( Red with Lt.Green stripe wire) another is "coil ground" from the ignition control module( Dark Green with a Yellow stripe wire). Your tachometer should be connected to the Negative side of the coil.
Just some guy
And not post Fox questions in the Fox section.
