Ok, I got a good deal (free, yee haa!) on a mini tach to fit in my speedometer cluster where the clock would normally go. I never had a clock, so this should work just fine. I mounted it in there, and all's well.
My question: One of the wire comes off the tach light (this must go to the + light switch), the second appears to be a ground, and the third is the signal wire. Do I hook the signal wire directly to the positive side of the coil?
Thanks!
Thespazardman
Negative side of the coil if I am not mistaken.
69 Sportsroof, 351C, 4spd toploader, Restomod BOSS 429 clone - the one and only (?) 1969 BOSS 351
http://home.swbell.net/boss351/mustang/boss1.jpg
http://stangnet.cardomain.com/user/adamg69
Try it on the positive side of the coil and if the engine runs
backwards just move it to the negative side <wink>
Actually, NEGATIVE side of the coil is correct.
D
Doug M.
1973 F Code Convertible, 302 4v, C4, and a lot more money to go!
(That isn't smoke, just Indiana on a warm winters day!)
http://24.183.185.135/Pictures/new_toy.jpg
