65 289. Bought a 4 wire tach and have a question. No problem with white (illumination), black (ground) or green (coil). The power wire (red) is, according to the directions, supposed to be connected to a source that is hot when the key is in the on position and off when the key is in the off position. I had plans to use the cigarette lighter but have found out that that is always hot regardless of the ignition key position. Seems like I read somewhere that the threaded stud sticking out of the back of the ignition switch would work (I don't know that for sure) but that is a bear and a half to get to for this fast approaching the age of 80 old fart. I am neither agile nor spry.
Do any of you have an idea of a source or wire that isn't so hard to access that fits the above description? If it is somewhere under the hood, that would be ok too.
Thanks in advance.
Chuck Sarsfield
Ft Myers, FL
Thanks in advance.
Chuck Sarsfield
Ft Myers, FL
