1 - 2 of 2 Posts
The left taillight and all four turn signals on my GT/CS have suddenly stopped working. The left taillight has no brake light / taillight/ emergency light or turn signal while the right side taillight/brake light and emergency flasher work as they should. The emergency flashers work in the front as well, just no turn signals. I've swapped out both flashers and the turn signal switch with others I had laying around and have the same results. I did have a blown fuse but I've inspected the wiring from under the dash all the way to the taillight housing and didn't notice any bad spots. Any ideas on what or where to check next? ::Thanks for your suggestions!
I'd first check that the wire from the tailight to the frame (ground) is still viable. Then, I'd check to see if I was getting any voltage to any of the wires going to that taillight. If so, then you've isolated the problem to the taillight. If not, trace the wiring back to the turn signal switch under the steering wheel (my guess!).
1 - 2 of 2 Posts
