Any suggestions on how best to remove a very stubborn differential carrier case from the axle housing??? All 10 nuts are off, both axles out, i've tried a slide hammer, did I miss something?
I started with a putty knife and worked up to a screwdriver and then a bigger one. If I had some help holding the housing it would have been a lot easier. That is a messy stinky job you are about to dive into. :: fd
Did you get the Washers?? those pesky washers will keep the center stuck good... Make sure all the washers are off then with some more coaxing it should dropp out..
There are soft washers under each nut that must be cut or pried off. At times one will leave a little piece in the threads. After removing all of the washers, leave a couple of the nuts slightly on (you don't want something that heavy to jump out) and gently pry the case. First put a pan under it to collect the oil. After it is loose and the oil has drained remove the two nuts and pull it. Be prepared for the weight.
