I have one of these on my '65. Rotating the plate gives four different camber adjustments. Note: both front and back plate must be rotated equally. The '65/'66 doesn't have the base plates so the first thing one has to do is to weld the base plates to the car frame in the area where the LCA pivot bolt goes. To do this, the existing bracket lower curved edge is cut away to allow the base plate to fit well (base plate is big enough it does not fit on the flat surface without cutting the lower lip). Once the surface of the existing bracket is flat, the base plate is welded onto the front side/rear side of the existing brackets. The central hole in the base plate is elongated and the original hole is round. The hole in the original bracket is elongated with a grinder to make it match the base plate. Once this is done, the rotable plate front/back is inserted over the base plate in one of the four positions and the LCA is reinstalled. The alignment is then checked and if the LCA needs to be repositioned it can be by removing the pivot bolt, rotating the plate to get the camber desired. Fine adjustments to camber can still be done by shims on the UCA. What I did was to make three spacers from steel strap stock, cut to a lenght just greater than the distance between UCA mounting bolts then drill holes to match the UCA mounting bolts. I slipped these spacers over the UCA bolts while installing the UCA. In this manner you have spacers (completely surrounding the UCA bolts) instead of shims that can fall out under heavy loads. These spacers fix the position of the UCA but provide for fine camber adjustment if the Vario-Centric spacing isn't exactly what I want. One added thought...the original bracket is cut away but in welding the base plate onto the bracket it is actually stronger than it originally is/was.
