Banned
I'm working on putting back a FoMoCo dizzy in the Cat. I'm sitting on a later vacuum advance.... one of the sealed units with molded fitting. Is there a way to easily test it off the car?
Yeah, it's not the right unit for the '67, but I'll replace it eventually.
I concur with Lemondrop Steve. Suck on the dizzy vacuum tube. You should be able to rotate the advance plate with moderate sucking. I know when I first got my coupe together it wouldn't move. A little clean up and lithium grease freed it right up, and she's been advancing fine for years.
Banned
Somehow, this feels like a setup for a practical joke, but OK.... A-sucking I shall go.
Ain't that the truth....
Any sort of suction device and a bit of hose should do the trick as well... maybe even like a big medical syringe (that uses the small tubing, not the needles) that you'd be able to extract the air with...
I remember back in the day a friend of mine made a robot arm using "hydraulics" through those kinda tubes and syringes....
Banned
Discussion Starter #8
I know that you're more sophisticated than that.... Had to break out the small words for others. Never let it be said that I don't look out for the little guy.
