@thatgreen66yote Coyote Swap Thread
25632 Views 455 Replies 27 Participants Last post by  602Raptor
Starting a build thread for the first time to document progress and get advise from the many on here who have dealt with the issues posed by this swap. My car has the second generation MII Heidts front end in it with an SBF and a t5 right now. Fueling is from tanks inc injection tank and Pimpxs. I mini tubbed it and installed an SoT 3 link, 9" with 3.89's and truetrac last year. Here in the planned parts list as of now.
Gen 3 mustang coyote(new or used not sure yet)
Vintage air front runner(not sure if I will be running a driven PS pump or Volvo electric)
T56 wide ratio with QT bell, 1330 yoke, clutch fork (will be here next week)
Running a cable for the clutch right now since I already have it. May go to hydraulic if the pedal is too stiff.
Ford control pack
Flywheel
Clutch
Pilot
Trans tunnel
Driveshaft will be Sot
Will run Manual brake's for now. Probably wilwood MC
Headers are TBD
Oil cooler nonsense is TBD
Radiator and fan are TBD
Seems daunting. Here is the car as it sits:
Car Land vehicle Vehicle Automotive parking light Vehicle registration plate
Tire Wheel Car Land vehicle Vehicle
Motor vehicle Car Vehicle Automotive design Automotive exterior
Vehicle Hood Car Automotive design Motor vehicle
Car Vehicle Motor vehicle Car seat cover Automotive design
Car Vehicle Motor vehicle Steering part Steering wheel
See less See more
6
  • Love
Reactions: 5
301 - 320 of 456 Posts
They are stickers that are placed where my welds are going. Lots of extra work but I decided it makes sense to have paint anywhere I can.
It did not even occur to me that your were simply masking the welds so you could paint. I took a different approach and sprayed the seam with copper infused weld through primer.
I could not replicate what Ford did with their spot weld through seam sealer. I figured anything was better than leaving the metal bare. I have had my eyes opened as I have replaced panels and found rust between the layers of spot welded metal, for example the tail light panel.
I noticed the same in the layers. Mostly surface rust in my case. I thought about the weld thru primer but read it doesn’t do much in the way of corrosion prevention and is a pain to weld.
I agree on the pain. I first tried the Eastwood WTP and after one use, threw it away. I got a UPOL copper infused WTP which I like much better. Still harder to strike an arc than bare metal, but I found if I scratched through the primer where the plug welds were to be made, no issue at all as the weld quality was good.
Reactions: 2
I use wtp then chuck up an end mill in my hand drill to remove the primer in the hole.
Reactions: 2
Wish me luck…
Vehicle Car Automotive tire Automotive lighting Hood
Automotive tire Hood Motor vehicle Tread Tire
See less See more
2
Reactions: 5
Lots of clamps to keep the upper cowl from shifting. I clamped in a copper backer under the lower layer to prevent blow through were the metal was thinned where you cut through with the spot weld cuter. A little insurance makes the job got quicker.
Good luck, show us the cowl after welding and grinding!
Reactions: 1
Didn't get to grinding on the window channel but I did sand the lip under the hood. May go over it with the welder one more time if I'm feeling energetic.
Automotive tire Hood Motor vehicle Bumper Automotive exterior
See less See more
Reactions: 5
I tacked all of the spot welds at the windshield lip as that was the only spot I had left to locate because the lower cowl is completely new. I then started in the middle of the lip under the hood and worked my way out. Then welded out both rows in the windshield channel. Went okay but there is more cleanup at the windshield than I would like.
Reactions: 1
Uh-huh. Sounds like me when I told you I didn't feel like welding in the cowl reinforcement for my strut tower brace.
"You're already there. May as well go ahead and do it" :LOL:
  • Haha
Reactions: 2
My .02: I think filling in the gaps on the support brace with weld, will make it look like less of an addition. Your work there looks great either way.
Reactions: 1
My .02 cents, I over did it, especially where the welds would be visible with the hood up. Just me as I sometimes don't know where good enough will do, the curse of being a retired aerospace/electronic engineer.
Reactions: 2
I couldn’t tell you how many projects around the house and/or shop that I had to “do over” because I decided to go for “better” or near perfect…. Many times “good enough” can be “the best”. 👍😜
  • Haha
Reactions: 3
Did some grinding and filling (weld) to make it a bit smoother. Got it sanded, cleaned, masked, primed, seam sealed and painted. Not bad for a days work. Here are some pictures in no particular order due to the unique way this site works
Automotive tire Automotive lighting Motor vehicle Hood Grille
Window Hood Automotive lighting Automotive tire Vehicle door
Hood Automotive tire Motor vehicle Automotive design Rolling
Hood Automotive lighting Motor vehicle Bumper Automotive design
See less See more
4
Reactions: 5
I was so paranoid on doing mine, I even set the fenders and hood in place just to double check my alignment before I actually started welding.
Reactions: 1
I just used the old holes in the windshield pinch area and the extensions to the aprons to try to put it back where it was. I will let you know how that worked out in a couple months.
Reactions: 1
I'm sure it will work out great. I also used those alignment holes but being I was in such uncharted territory for myself, I was taking a lot of unnecessary steps to doublecheck myself. Still do...one of the reasons I make such slow progress..ha ha
Reactions: 1
I would suggest we are a lot more concerned about exact alignment than was Ford. I think we will all find that the cowl replacement will go just fine.
Reactions: 2
Quick update. Felt like it couldn’t wait as I’m sure @LSG is on the edge of his seat.
The cowl held me up for 5 days because the seam sealer got sticky once it was painted. Super fun. 4th time sealing and painting was the charm (used different sealer).
Today I bled the brakes and checked for leaks. Installed the fuel lines and checked for leaks up to 80 psi. Then dialed it back to 55 psi per the control pack instructions (more questions on that later). Took the passenger header off and used a bfh to clearance the bell and starter bolt because it moved during welding. Installed the PS lines on the rack. All was good so I installed the engine and transmission. The intake is just sitting on the engine not installed. Maybe tomorrow. It’s not likely I will make my goal of starting it this year…
On to the pics obviously in no particular order do to the unique way this site works.
Motor vehicle Hood Automotive design Car Automotive exterior
Motor vehicle Automotive tire Automotive design Vehicle Automotive exterior
Vehicle Car Hood Motor vehicle Automotive design
Automotive tire Hood Motor vehicle Vehicle Automotive design
Motor vehicle Vehicle Automotive design Automotive exterior Automotive air manifold
See less See more
5
Reactions: 5
Ready to rumble? 2023!
Reactions: 1
I want to be driving it around with it fully assembled by February. We shall see. Burn out could be a factor.
Reactions: 2
