I understand burnout! Best to have a clear head when lighting the candle the first time!
I understand burnout! Best to have a clear head when lighting the candle the first time!I want to be driving it around with it fully assembled by February. We shall see. Burn out could be a factor.
I'm right there with you, bud. We're so close, though! Maybe a day out at AMP with Mike and co harrassing us will help......I want to be driving it around with it fully assembled by February. We shall see. Burn out could be a factor.
Seems it’s the same. Going to have to run a relay for the mil light. In other news ITS ALIVE!Greetings Angry,
When I turn my key “ON”, my fuel pump only runs about 2-3 seconds. (No tune yet). It obviously comes back on while cranking/once engine starts.
MIL: My gen2 harness had a BLUE (BU) blunt lead 4, and RED (RD) blunt lead 6 wire that connected to the MIL. The red is Posative and HAAT - hot at all times. The blue is ground from the computer. Grounded only if a code/fault is present. So with the key off there should be no ground present on the blue wire thus MIL off.
Not sure how different the gen2 vs gen3 harnesses are. See below for my instructions (see cavity/lead 4 and cavity/lead 6)
My initial start was open headers.. Off course even after I installed the exhaust it was just as loud.. The noise was “further back”…..😵💫
And it's ROWDY!In other news ITS ALIVE!
Where is the first start video? You know the rules, without video confirmation, it didn't happen.Seems it’s the same. Going to have to run a relay for the mil light. In other news ITS ALIVE!
Click it’s alive in my last post.Where is the first start video? You know the rules, without video confirmation, it didn't happen.
Thanks, missed the link. Sounds pretty mean IMO. Love the screams in the background when it came alive! Now comes the first road test.Click it’s alive in my last post.
It’s still warming up. I didn’t have the fan wired in until last night and wanted to get the coolant leak fixed so I could purge the coolant system. Probably try that today.Sounds great!
Was that 1000rpm idle still “warm up“ or is that where yours sits? Just curious as mine full hot is still around 900rpm. Others have mention closer to 600-700rpm idle post tune.
Next vid better not be you on a Lowe’s bucket driving around the neighborhood…. 😜
Buckets aren't safe! You can borrow my milk crate!No buckets for me😂.
