Vintage air front runner. As many of you know this is a pretty nice kit. Some of the machining is a little goofy but over all it looks nice. One word of caution for you long haulers is that I see no way to change a belt without taking it apart.
I have the same setup and you are correct!to change a belt without taking in apart.
They are available but the cost would have been the same had I set up my crate like yours. I figured since I was using the rest of the VA kit I should go this direction. Your build is incredible and if I find myself near you I will be messaging you to swing by to see it. May be headed to munds next month.I have not seen the value in using the front runner accessory drive over the Ford OEM accessory drive. Now, in all fairness, my engine is a low mileage take out from a 2017 GT, so I got the accessory drive, AC compressor, and alternator for free with the engine. However it fits very well in my 70 Mustang using the TCP front subframe. It is easy to change belts or other components and the KRP PS pump is designed to work with it. Is there some advantage I am missing, not criticizing you choice, just curious.
Although I have never checked but I would think the Ford OEM parts should be available.
Gauges look great. Did the manufacturer include the single disconnect Molex connection? I did something similar on my Factory Five Cobra when I wired the Speedhut vintage gauges for it. The single disconnect is very handy if you ever need to service the gauge pod, or just remove it to gain access to something behind it.
I don’t know what molex is but there is a single disconnect in the second pic. It’s white.Gauges look great. Did the manufacturer include the single disconnect Molex connection? I did something similar on my Factory Five Cobra when I wired the Speedhut vintage gauges for it. The single disconnect is very handy if you ever need to service the gauge pod, or just remove it to gain access to something behind it.
Yes that is the Molex connector. Molex is just a term for a line of connectors that have been common place for decades.I don’t know what molex is but there is a single disconnect in the second pic. It’s white.
Oops. I never said. New vintage USA. They are the 69 series. It was between that and the Dakota but I don’t like the small tach and these were very cheap compared the them. I asked them questions via email and they were very prompt to reply and sent me a 10% off code. Main thing is that the speedo is electronic so I can eliminate the cable.Nice. I apologize if I missed it, but who was the vendor / manufacturer for the gauges?
So, I was at my friends shop Saturday and I asked him about the Volvo pump and steering. He really likes it, says the road feel is great. In fact, he had just picked up a new project, a 63 F100, and intends to use same setup in this one. He got a steal on the truck, someone had already done a very, very nice job of installing a Crown Vic front end and new floor pan and then got bored with the project. Got it for way under 2K. Picked up a Coyote F150 for a decent price and will be dropping it in there.I believe it would be a viable option but I haven't actually driven the truck so hard for me to say good or bad. He has the pump mounted up under the fender and there is just a little sound from it when you turn the power on but you can't here it at all once he lights the fuse on the Coyote.
I'm sure he would give you his thoughts on it, functional and budget wise. I need to get over to his place and return his Coyote lift plates and check out his twister build so I will see what he thinks now that he has lived with it for a year.
Nice! Wish there were deals like that here.So, I was at my friends shop Saturday and I asked him about the Volvo pump and steering. He really likes it, says the road feel is great. In fact, he had just picked up a new project, a 63 F100, and intends to use same setup in this one. He got a steal on the truck, someone had already done a very, very nice job of installing a Crown Vic front end and new floor pan and then got bored with the project. Got it for way under 2K. Picked up a Coyote F150 for a decent price and will be dropping it in there.
Also has an 86 (?) F150 and complete Crown Vic he will be combining soon.
Almost done with his Mustang Twister.
Easy answer is you are. I hope to fire it in December but that's a lofty goal. Every time I stare at it I remember or see something else that needs done. The never ending list is only getting longer. Even the metal work(which I usually like) seems daunting. Even debated getting the prefabbed tunnel you have to save time, but I don't think its tall enough. Then on to the parking brake. As high as the drivetrain is I'm not sure there is room. On the plus side, most of the expensive things are bought. Only big ticket item I have left is AC components. Then there will be bugs to work out, tuning, carpet. Long way to go!So, which of us will be the one to drive their running pile over to the other's house first?
That's the real question!
That's an interesting find. The manual for my Tremec T56 Hydraulic Release Bearing (P/N 60-6105) indicates a full stroke of 0.70". I imagine that this travel is reduced by the initial setup of 0.125" clearance so the practical travel is down to 0.575" max. It also states that most diaphragm requires 3/8 to 7/16" for disengagement and 0.5" for 3-finger diaphragms. the HRB displaces 0.604 ci @ 0.5" (stated in installation instructions). The 1968 mustang Malwood with a 0.75" bore and 1.375" travel displaces 0.607 ci which would reach the 0.5" travel needed for the worst case diaphragm requirements. What displacement are you going the get at 0.81 ci volume and why do you think you'll need more than 0.5". ThanksBeen talking to Tilton about my HRB the last couple days. They have not been very much help but its likely for liability reasons. Gave them the bore and stroke of my malwood and asked if it was 100% necessary to put in a clutch stop. They said yes. I found the data sheet online for the bearing and did the math and I think I can get away with not running it. The bearing has a capacity of .81 ci at full stroke and the malwood pushes .61 so I should be good assuming its enough to disengage the clutch.
Oh good call. I didn't think about the .125 clearance and how that would effect travel. I just did the math based on the Tilton piston size(1.215) and the .700 stroke to make sure the Malwood wouldn't exceed the HRB's capacity. My main concern was over extending the bearing as it doesn't have a stop inside of it. Did you add a pedal stop? Tilton seems to want me to install one no matter what. They said if it compresses the pressure plate too far that it could cause issues.That's an interesting find. The manual for my Tremec T56 Hydraulic Release Bearing (P/N 60-6105) indicates a full stroke of 0.70". I imagine that this travel is reduced by the initial setup of 0.125" clearance so the practical travel is down to 0.575" max. It also states that most diaphragm requires 3/8 to 7/16" for disengagement and 0.5" for 3-finger diaphragms. the HRB displaces 0.604 ci @ 0.5" (stated in installation instructions). The 1968 mustang Malwood with a 0.75" bore and 1.375" travel displaces 0.607 ci which would reach the 0.5" travel needed for the worst case diaphragm requirements. What displacement are you going the get at 0.81 ci volume and why do you think you'll need more than 0.5". Thanks
