I have a 1968 Mustang Coupe, I'm using a 15 x 7 rim, can I use a 215 /60/15 all the way around ( all 4 tires ) without any problems? I have drum brakes, the car has not been lowered yet. Will I have any problems using a 215/60/15 tires. Thanks in advance.
Ran 15x7 with 4.25bs for years with 215/60-15 and I’m lowered about 1.5-2” all around. No issues.
yep even with the less than Ideal yet more common 3.75BS
In fact If you have 15x7x4.25 you could ru
In fact If you have 15x7x4.25 you could run 225/60/15 Squared
Thanks for your help, I double checked the backspacing on the rims that I am going to use and they are a 3.75 backspace. Thanks for your help
