Call Alex at Money Maker Racing, he is a dealer for Flex-A-Form. Not sure if they are the same company as Flex Form but he will be able to tell you. Flex-A-Forms will run you about $400.
Ditto on the above link. I also had this link bookmarked last year but the domain no longer exists
http://www.flex-a-form.com/
There are some guys on mustangsteve.com that have used these springs if you wanted to post a question. I was going to post the mustangsteve archived thread about this but its expired now
Never owned a set....let me say that first thing.
Have heard plenty about them. As many positive comments
as negative.
Seems like the pricing was in the mid 400's for a pair.
Most of the positive comments are that the factory used them
in some applications and they survived just as well as steel springs
but with a much better ride.
The negative comments were mainly related to failures due to
fractures caused by improper installation and failure or fracture
again at the eyelet locations due to side-loads or twisting of the
spring due to side loads from cornering. The factory fiberglass
springs combat this through compliant rubber bushings and either
a panhard bar or watts link.
I won't use glass springs. To me they are a solution looking for
a problem.
There's been quite a bit written about this FAF on this forum
and corner-carvers.....
ex-Global West GM
1991-1994
Thanks for the input GT289. My concern with what I see on the market is that stiff bushing, I am pondering a watts link (Fays) and I would like the springs but with a more compliant bushing. From what I have seen that hard bushing is not really going to work for me.
You're welcome.
I'm one of those guys that started out back in the early 80's
going with the "tried and true" 620's, 200# Maier leafs, Konis
front and rear, etc......what a disappointment. And all of that
stuff went into the dumpster.
My quest for correct suspension answers after that fiasco led
to a career in the automotive aftermarket.
I won't steer you wrong (no pun intended).
So far the only thing I can find that I may like is the mid-eye 4 1/2 leaf from Opentracker. I dont know how stiff I want it to be, I am pondering a rear seat delete, all of that associated stuff is kinda heavy so I dont want to over spring the back half.
150#/in is the hot ticket in a 65/66 afa a steel leaf spring goes.
Whatever that converts to in a fiberglass spring....
