41 - 54 of 54 Posts
Discussion Starter #42
How are you going to located the floor supports?
So tomorrow I’m going to mock everything up like the fire wall the cowl both torque boxes the floor supports and the frame rails/aprons so while everything’s mocked up I’m going to take the measurements and mark the holes for the welds I’m not sure yet though weather or not I’m going to put the holes in the floor support and weld it to the floor pan or weather I’m going to put the holes in the floor and weld to the floor supports so not sure but either way whilst everything is screwed and clamped Into place I’ll figure it out and mark for my spot welds!
I concur with Dave. Seems like the more of the floor that gets welded in the more misaligned it seemed to get. If you put the holes in the floor you stand a good chance that they won’t line up with the support once you start tweaking. If you put the holes in the support there’s a 100% chance the weld will be smack dab in the middle of the support flange where it’s supposed to be.
Discussion Starter #45
Well that’s why I’m here...I appreciate it that’s what I will do then!
Discussion Starter #46
So I got the torque boxes welded in and the fire wall and cowls clamped/screwed into place. This weekend the plan is to screw up the front clip that I built on the floor and then once everything lines up and fits the plan is to weld it in one piece at a time
745670
Discussion Starter #47
746344
746345
The front clip is now built(just screwed together ). So hopefully this weekend I can get it mocked up on the car to line everything up and tweak it. Then everything comes apart and is welded in order of how it goes back together!
So then you bolt up the export brace and that give you your top point. Do the frame rails only fit onto the floor supports one way? Interested because I may be in the same predicament one of these days.
Discussion Starter #51
The floor supports weld to the one piece frame rails/aprons and then it all slides in
746484
746485
Are your floor/firewall welded in? From the 2nd picture in #47, it looks like your floor is below the firewall. Shouldn’t it sit on top of the firewall?
Discussion Starter #53
Nothing is welded in yet...but the floor was under the firewall in that picture I just dropped the fire wall in to see what it looked like. But now it’s on top of the fire wall and boy does it make a difference!
Discussion Starter #54 (Edited)
Been awhile...so I got the firewall front clip, supports and torque boxes welded in and I primed the front end and the places that I won’t be able to get into after I weld in the cowl. That’s pretty much where I am up to now but I’m home for awhile like everyone else so I plan on getting the car buttoned up and painted before I go back to work.
750389
41 - 54 of 54 Posts
