I thought I would post a few pics showing the spreader bar in action. I wounds up soaking the feet in acetone for a day to remove the adhesive of the rubber pads. I did this because the original adhesive was slipping when I tested the bar the first time. I re-attached the pads using the jell style super glue, and as you will see, it worked perfectly. The paint wasn't as hard as I would have liked, and the pads still didn't leave a permanent mark. Note that I put the pads just underneath the support mounts on the shock tower to prevent the spreader from slipping "up". The spreader did climb a bit, but not enough to damage the support mount. Anyway, take a look:
http://albums.photopoint.com/j/View?u=1571656&a=12306790&p=45617449&Sequence=0.jpg
http://albums.photopoint.com/j/View?u=1571656&a=12306790&p=45617455&Sequence=0.jpg
http://albums.photopoint.com/j/View?u=1571656&a=12306790&p=45617467&Sequence=0.jpg
Shannon a.k.a. The ShanMan! /forums/images/icons/cool.gif
66' Vintage Burgundy C-code coupe
http://albums.photopoint.com/j/View?u=1571656&a=12306481&p=42935059&Sequence=2.jpg
Handy looking tool. Certainly usefull for installing export braces.
68 GT500
68 1/2 CJ Coupe
MCA# 18519
Neat Tool! I have to have one of those. I can think of a few other places it would come in handy.
What did you use for those swivel feet?
Greg B
Shannon,
Make sure to get your front end aligned prior to driving your car for any distance. You probably have changes the camber and toe of the front end.
http://albums.photopoint.com/j/View?u=1571478&a=12409371&p=45514468.jpg
Discussion Starter · #5 ·
Based on the amount of creaking the car made during the spreading, I would say its a certainty! Thanks for the advice.
Discussion Starter · #7 ·
Like the rest of the parts, the swiveling levelers are standard issue from a Mcmaster-Carr.
VERY Nice, VERY VERY Nice!
Tom Kubler, Long-time Mustang Enthusiast & San Antonio Mustang Club Founder
