Multi-rib grips better, and Goodyear has some tech articles as to why if you're interested. That said, one of mine is V-belt with a 3G 130A and spec belt tension, and like others never squeals. I have solved squealing before and most times it is worn belts or pulleys.
From my aviation-tech days, the grooves must be clean and level with no worn waviness, pits, corrosion, or run-out. Effectively, look like new with some sheave polishing, but without distortion in the reflection. Our old pulleys rarely are. Likewise, the V-belt must be the same, with no glazing, shiny surface, cracks or age-hardening. Belts are done for good grip after ±5 years due to hardening, and like old tires don't grip as well.
Worn pulleys wear the belt, and the belt then wears the other pulleys, but never the same pattern so the grip is greatly reduced at every point. The worst point squeals, the belt almost instantly glazes, and here we go again. BTW - the same things can happen to multi-rib.
So now the method that has worked 100% for decades when changing
new belts, that will freak-out some readers. It freaked me out. Following some of my tech instructor guidelines for certification, they told me to install the new belt with a
tiny rub-in of grease.
Yes, a dab of grease rubbed invisibly into the contact areas of the belt with
no excess, just this once. Installed and properly tensioned, the grease works for only a few minutes at low speeds to help the belt seat to the pulleys, while avoiding belt glazing from frictional heat of seating and any slippage (usually none) until it seats. The belt is considered "used" after 10 minutes running, and re-tensioned. I would have never believed it before, but damned if it doesn't work, and every time.
Related tip: I found my pinky finger can apply about 4 pounds of pressure without pain. Cool. At 4 pounds pressure at the mid-point of the belt span, there should be 1/64" deflection per inch of span. So, on a 12" free span of belt, it should deflect 3/16". Now I can properly tension my belts without any special tools or guessing, for maximum performance and life of all the parts affected.
Grab your scale and see what tools are on your hands.
