I found this information here
754785
some time ago about using a 65 Chevy brake light switch in a 65 Mustang. You remove the brake pedal stop and place the switch in its place. Move the wires over and you're done. It is a bit difficult to install it, but nothing like the original. I'm 6'2, 240 with 3X hands and it is extremely difficult for me to work under the dash. This was a big problem solver for me.
754783
Any chance of a picture of the install? I am wrestling with a 65 brake switch, cannot get the pin removed.
I will give it a shot. Basically you find the rubber stop on the frame in front of the brake pedal actuating arm. I had to cut mine out with a flat Xacto blade. Then
754819
put the threaded end of the switch through with only one nut in back. Screw on the other nut and adjust to length. It's a very confined space, but nothing like the original switch from hell. I've read threads on here where someone took over 6 hours to remove and replace that switch. Dropping the steering column helps and pushing the pedal forward clears a bit, but the original is still a real bitch to change. The wires look closer to the original switch than they actually are.
Nice job but I'd put some shrink wrap on those female terminals. Exposed "hot" wires give me the willies.
