Quick question...
Does anybody know if there is a diameter difference between the powersteering tierod and manual? The reason why I'm asking is that I'm placing a baer bumpsteer kit on the fastback and the driver's side won't go on. It appears that the inner tie rod is bigger in diameter than what the Baer one I have is designed for.
I have a '66 coupe w/ manual steering and a '66 fastback w/ power, and the tie rods on the PS car are definitely different. The driver's side one on the PS car is much heavier. I understand the bump steer kits don't fit PS cars, and I guess you just found out why.
MrFreeze
6 cyl manual vs 6 cyl ps are different sizes.
V8 manual and power I thought are the same diameter,
the tie rod is bent on the LH to clear the control valve,
maybe the thread is different RH vs LH thread?
Vendor
copasspupil said:
Clearly different diameters for v8's. I just picked up a Moog MS LH inner and it screwed right in. That part it done. On to the clutch issue.
So you had a 6cyl one in there or a power steering one?
