Just for future refernce, I narrowed the play in my steerng down to the universal joint inside the tilt steering column mechanism. I pulled the unit by removing the tilt pins, and then tightened the bolt holding together the yoke components. Souns simple, but it wasn't! as I had to re-thread the tilt pins to use the pin puller.
If anyone wants a step by step on this plus pictures let me know.
I would like to see how you did it. I got a tilt unit in my trunk when I bought the car, but it is in pieces. Pictures might help me see if this is worth doing.
Thanks,
[email protected]
I too have tilt wheel problems. What was you problem with tilt?
Could you send me pics of how you cured this.Would be helpful.
Thanks.
I too have tilt wheel problems. What was your problem with tilt?
Thanks.
Discussion Starter · #5 ·
My problem was the universal joint in the top end of the steering column that had come loose. What is your problem?
