Today I had to remove the oilpan because I used a to small block of wood between the jack and the oilpan. You can guess what happened !! After removing the pan I checked the timing chain and noticed quite a bit of slack.
I know this chain and sprockets have done 45000 Miles and that they are replaced in 1988. Is it wise to replace the chain and sprockets after this 45K mls ? The engine is running fine .
Erwin, The Netherlands,
Visit my homepage at : http://home.hccnet.nl/e.pilage/index.htm<P ID="edit"><FONT SIZE=-1>Edited by 66candy on 03/13/01 04:05 PM (server time).</FONT></P>
