1 - 18 of 18 Posts
I have the timing cover off for gasket replacement, and it occurs to me that this would be a good time to check the timing chain. Shortly thereafter, it occurs to me that I have no idea how tight it should be. Is this good, ok, bad, laughable?
Just some guy
You should check it how Woodchuck says but honestly it looks about right for a link belt style chain. I quit using them after I found new ones stretched out about as far as the ones I was replacing in about two thousand miles. I've used full roller timing sets ever since.
64 1/2 D Code Coupe,
Now is the time to replace it with a Cloyes Dual roller timing set.
yup the "while i was in there" factor........dont do what i did.
I replaced the TC but left the WP because it looked good. then back in there next summer for a WP that I should have just did "while i was in there"
Discussion Starter #11
I continue to find ways to make easy things difficult. Two new issues.
1) This ring was behind the lower sprocket. When I put the Cloye's sprocket on there, it won't go in far enough. Is this just a spacer that I can safely remove?
2) When removing the lower sprocket due to the spacer ring, i managed to turn the crank, and so I'm now out of sync. How do I get myself lined up correctly?
Thanks,
TGV
745765
Discussion Starter #13
Should there have been instructions with the timing chain set? There was nothing but two sprockets and a chain in the box.
That's not a spacer ... it's an oil slinger.
And it's in the wrong place ... should be in front of the sprocket, not behind it.
It's a lot easier to turn the crank if the plugs are out. You can put the pulley bolt back on and turn it with a wrench. Or you can put the pulley on loosely and turn it with your hands. It won't be hard to turn with the plugs out and the cam not connected.
1 - 18 of 18 Posts
