·started to put on a double roller chain timing set on the 66 this weekend , from NPD, and found the cam
pin didn't stick thru far enough to catch the pump eccentric, face of the cam gear has a raised center.
did i order the wrong part? (cat says fits 66 to 73) get the wrong part? (part numbers right) or do i need to
replace the cam pin? this is on a 66 2v, engine id is 66 also thanks to kbstang. thanks all.
66 Coupe, 289/2v, C4, CA Red
