Timing Question
611 Views 4 Replies 3 Participants Last post by  Opentracker
What is the best degree to set a stock 351C. I know this is a
simple question. But I have a simple mind :)
http://albums.photopoint.com/j/View?u=1603896&a=12227373&p=44503083.jpg
73 351C C6 3.25 T-lock
Jesus is all the world to me!
Mustang's are just a Hobby
http://www.folksite.com/TFOB
n/m
http://albums.photopoint.com/j/View?u=1575962&a=11982331&p=43165927.jpg
67 Sports Sprint, Convert. Original C code,
Now 293 ci with Holley 450 and 295,000 miles
MCA #49294
Yep! Road timing is the best way to get it right. There have been
a few post on how to do this. You drive the car, keep turning it up
till it pings, and set it back a little. I take a 1/2 wrench with me and
work on it for a few days if need be. It shouldn't take more than a
few runs but, it gives me a reason to go out and run the car!
I just posted a question like this a couple of days ago. Here's basically what I am doing. I learned that because of the age of engine, that the timing ring may have slipped so the degree measure might not be accurate. If you have a vacum gauge, adjust the timing until you have the maximum pressure (which should be about 10-12 degrees). If the engine starts pinging than back it off a bit.
MustangDave has a good idea there. That would give you a good
starting point.
