1 - 9 of 9 Posts
Want to star at by saying i think i have read every thread on this and other forums ( all of my posts and questions are here). I have learned more about timing a 289 with an autolite 2v, than i ever thought possible. And still dont know much. Have read tremendous advice from ivy and the other legends. Here’s where I’m at.
had a “rebuilt” carb purchased off eBay to get a number matching carb. Was running rich to say the least (topic of another thread i got a lot of help on). Car is very early dearborn 64 1/2 vert with a 289 ( another long story). newly rebuilt carb, everything stock, just put in new points (gapped at .017), condenser. Set initial timing at 6 degrees before top dead center. Definitely have tdc correct, not 180 out.....ride it up today with my timing light and tachometer. Adjusted both ideal and advance to the point where i could get the idle down to about 700-800 rpm with the advance at 6 degrees. Ideal screw on side of carb completely backed out. Prior, i could only get the engine to run at about 1400 rpm and the timing was at 6 degrees. I adjusted the idle screw along with the advance And was able get the idle down to about 700-800, not lower. This was all done with the vacuum hose removed from the vacuum advance and plugged tightly.
with all i have read, and i am pretty sure i have googled/ searched every post on just about every forum. I am stumped. I understand that idle should be at about 600 rpm. I cant get it that low. At 700-800 now, it sound smooth. Best i have had it. Trying to get it right at idle before hooking up the vacuum advance.
any advice for the novice/google/forum guy?
as always thank you all for your time and expertise....
This is not a crowd you need to worry about spelling ;o) Couple things I would check after Travis' suggestion, make sure your butterfly valve is well centered and closes well. If its truly running rich, a vacuum leak will make it idle higher. You can try plugging vacuum lines like to an automatic trans with a bolt to see if it makes a difference. You may end up going into the carb to insure it was rebuilt right and all the passages were cleaned out correctly.
By the way, since you are working to get everything right, you need to purchase a dwell meter. Point gap is a starting point, dwell or the number of degrees the points are open is the right way to set points. You may end up buying an old used one as I doubt anyone makes them any more but its that last little dial-in. we all used to have 'em in our tool boxes.
As you may have read from so many other posts, 6 degrees BTDC initial timing is very late with modern pump gas, and may be at the heart of your problem. 10-12* is a much more appropriate point for your setup. Also, the specs for idle RPM as given by Ford were for a car “in gear” and not in park, so don’t drive yourself crazy by setting idle too low and having it stall when you put it in drive.
Discussion Starter #9
Ok, i am officially an idiot....The high idle was indeed engaged. Travis thank you. In kicking it down, it hums at a little Over 600 rpm, timing at 6 degrees before tdc. I will advance it a bit and see how it runs based on the input above. Can’t thank everyone enough. I will work with all of the advice here.
1 - 9 of 9 Posts
