1 - 10 of 10 Posts
· Registered
66 Inline 6 (PS/ Auto/ Factory AC Removed)
Engine is out.
Need to replace the PS shaft boot, the end nut on the shaft end seems stuck but I don’t want to damage anything.
Any tips to remove it?
Steering box coming out for a rebuild. I’ve seen some older videos. Any tips for this too?
thanks.
Automotive tire Wood Floor Asphalt Gas
Motor vehicle Automotive exterior Gas Auto part Vehicle
· Registered
To remove the steering box, you have to disconnect the rag joint and unbolt the pitman arm from the linkage. The box is mounted with bolts through the outside of the frame rail.
On the shaft, I believe there's a flat spot where you can put a wrench on it so it doesn't turn. You can heat the nut up with a propane torch.
Automotive tire Motor vehicle Gas Auto part Machine
· Registered
· Registered
The gearbox and up is the same between V8 and I6. Everything below is different. Still the best answer is Chockostang. If they are rebuildale, I would much rather get my original stuff rebuilt, mainly because I know it is the right stuff and fits.
I6 with PS is a very rare beast. Good find.
· Premium Member
When I bought MyFirstCar at 16, over 30 years ago, the seller also had a 66 convertible with power steering, power brakes, AC, power top, Deluxe Interior with console, Vintage Burgundy with Parchment interior. It was absolutely gorgeous. But I could only buy one car, and being 16, of course I went with the 289 V8 auto hardtop.
1 - 10 of 10 Posts
