I bought some 15x7 3 3/4 backspacing torque thrust D's for my 1965 mustang coupe.My car has a slight drop look to it already but I was wondering what size of tires would look good on my car being that it has a restomod look to it.
The 3 3/4" backspacing is really going to limit the width of the tire possible.
Something like a 215 60 would be feasible though.
I took my car to the tire shop and told them to put the biggest tire that would fit on my wheels (same diameter and backspacing as yours...at least back then)
I was really disappointed when they installed 205-60-15's on it. Said that was all the could do. The back is no problem...but the front is tight when you take a turn and the springs compress (worst case is a hard turn and a bump into a concrete driveway for instance).
There are car to car differences...so you may have more luck than I did. I'd highly recommend letting the tire store make the call. That way if it's a problem, you'll have recourse to get it straightened out on their dime.
Phil
Gone but never forgetten
Depends on if your fender lips are rolled or not. With rolled lips, you can fit 225/60's in the back. Without rolled lips, 215/60. Fronts I wouldn't go more than 205/60.
I have 225/60's in back and 205/60's in front on my '66 with the same wheels as you. I rolled the fender lips a couple weeks ago because I was tired of banging the rear tires.
Is 3 3/4 the standard backspacing for TT rims wether they are IIs or Ds. I was thnking about 15x7 rims with 225/50 all around. The lips are not rolled. Will I have a problem? What size tire could I use if I went to a 16" tire?
