So when they say 65 Red/white 2 tone the white is not really white? Or is it the factory color they said is white? I ordered a can of white from NPD but it a bit lighter..
Window Sleeve Fixture Skyscraper Tints and shades
read this description from the NPD site, its about visors but explains the difference.
"VISORS, Original Style, off-white, pair, Sierra grain vinyl, correct early 65 standard off-white and all 65-66 deluxe (Pony) white, Will only match other off-white components made by TMI, pair, The Sierra grain style is an exact duplicate of the original and utilizes anti-microbial thread throughout it construction, The material itself is mildew resistant and they are matched to the original pattern for an exact fit that is easy to install, Our visors are manufactured for the serious restorer and are intended to last as long or longer than than the original product, Any trim shop professional will tell you, visors that are made properly not only take less time to install than a bargain brand, it looks better and lasts longer, This difference in quality translates directly into dollars when a trim shop has to re-stitch improperly sewn seams or make adjustments to fit poorly built patterns, Expect professional results when you install the Mustang visors built for the serious restorer, Manufactured with close attention paid to proper stitching with correct edge trim, correct rod sleeves and design features, When you consider the cost savings of installing only the finest visors, These stands out as the clear choice, "
VISORS, ORIGINAL STYLE, OFF-WHITE - #VC-5-E - National Parts Depot
The TMI white (color 2290 I believe) is very pretty, but more of an ivory cream color. I’ve also found NPD’s paint to be a bit lighter. These are my white door panels from TMI:
Grille Hood Automotive lighting Vehicle Automotive exterior
