1 - 9 of 9 Posts
66 Mustang
Anyone else use the full length TMI console? I'm running a 4r70w and waiting on the TCI outlaw x shifter to arrive. Its touching the classic auto air hvac box, so I might need to cut it a bit. Just wanted to see how far you may have yours forward...
752013
752014
752015
If you trim the fiberglass and not the vinyl it will form nicely around the box. Mine required quite a bit of trimming, it’s out right now so I’ll try and take a picture of the cuts shortly. I have mine all the way up under the dash so it flows nicely, quite a bit further back than your initial mockup.
752016
Reactions: cturboaddict
66 Mustang
Yeah, if you could grab a side shot that would be awesome. I think it needs to match up with the base of the dash.
66 Mustang
You can see how I trimmed mine to get it in there all the way. I have mind so where it rolls down towards the DIN opening is flush with where the dash tucks under flat.
752160
752161
I'm running lokar shifter with 4r70w, i had to trim the fiberglass a lot to get it to fit how i want, you just lift up on the vinyl wrap, trim/grind with a carbide bit or dremel then push down the vinyl.
752191
Which console did you guys order? TMI makes one for a/c and w/o a/c. I ordered the one with a/c and on mock up it seems to fit fine so far. I too have a 4r70W in my car. However, we modified a stock shifter to work with it.
Here is a few picks of mine. I could not tell the difference between the 2 on TMI's website
66 Mustang
Discussion Starter #9
View attachment 752284 View attachment 752283
I ordered without AC. But I'm running classic auto air. I figured it would have a gigantic notch for the big ac pod that is traditional to the 66 mustang.
1 - 9 of 9 Posts
