To any who went from 2v to 4v
979 Views 8 Replies 6 Participants Last post by  Guest
I saw an ad for a local parts store selling a Holley 4v for $183. I though this was pretty good and would like anyone's opinion who went from the stock set up 2v, to an aftermarket 4v what they use and would they recommend it. I am only going to purchase the carb and intake at this time. Also I have single exhaust, but do have plans on the horizon for the dual set up. Also the engine I have is tired and needs a rebuild. Should I go and make the purchase or wait until I have the exhaust or rebuild done.
66 Signal Flare Red Vert
302 2bbl
1 - 9 of 9 Posts
· Registered
· Registered
Do you know which holley 4V it is? If you can post the type or list number, then it will be easier.
I went from 2v to 4v. Loving more horsepower, it was worth it. /forums/images/icons/smile.gif
Rob
Member: Slightly Modified
66 coupe 302
66 fastback 351W
· Registered
I agree with these guys about making the purchase now to score on the deal. I assume that the carb is an 1850 or some cousin of that? Is it vacuum or mechanical secondaries? Keep in mind too that you can get a very good Edelbrock carb for $195 every day of the week. You can't get quite as much power out of it, but it will be very reliable, with consistant performance. Cooincidentally, i have both carbs, and will be installing the Edelbrock until I can get new heads, cam, etc. Good luck!
Shannon a.k.a. The ShanMan! /forums/images/icons/cool.gif
66' Vintage Burgundy C-code coupe (mine)
95' XLT Ranger (mine)
01' GLX 1.8T New Beetle (hers)
What kind of intake comes with it? I have a an old original iron intake for my 4v, but you should upgrade to something like an aluminum Weiand or Edelbrock intake. My friend has a Weiand stealth intake on his '68 and he loves it.
· Registered
I bought a 600 Holley, vacuum secondaries,electric choke at a parts store right in my town. I paid 219.00. I figure any v8 Mustang should have one. I had to do very little adjustments to the Holley, slight adjustment on floats and idle and fast idle. Works great, I have a Performer manifold too.
· Agitator
Put a Holley 600, vacuum secondaries, electric choke and an Edelbrock Performer intake on mine......Love it. I recommend the purchase. Add headers and dual exhaust next, it will free up the breathing a bit and make you smile when you hear it. This should allow you more performance, even on a tired 289. Rebuild or upgrade can come later and the parts can be re-used....
When I can't stand, I must lean...
When I can't see, I must believe....
The holley I bought when I converted mine cost over 200 bones that sounds like a good deal cause you can buy a rebuild kit for about $15-$20.
1 - 9 of 9 Posts
