I am going to change the front seal on my Toploader tommorrow, does the gasket which retains the front seal require sealant? How about the bolts, are they wetted into the case?
The cover gasket goes on without sealant. Bolts need sealer otherwise gear lube will come out past the threads, wetting and ruining the clutch.
Thank you, that was my concern.. what sealant is best, Permatex ?
