I have a toploader that started leaking. It seems to be coming out the front of the transmission. Are there any seals on the input shaft ? If so where would they be, is it the bearing itself?
There is a seal in the bearing retainer. Take the 4 bolts off pull the retainer off and you will see it.
69 Mach 1 427 Windsor
It could also be the cluster pin which runs through the trans and the front end presses into the front of the case from the inside.
Usually has a swipe of silicone over the very end. If your leak is there it's usually the case that has worn out and not the pin itself. Rare, but it happens.
