1 - 11 of 11 Posts
So I got a pair of torque boxes with the car and they fit like $h!t. So looping for a good fitting set that are 2 piece any one have a suggestion???
Most have to be massaged.
Seems like the left side is the issue on the fitting. It just don’t fit the shape of the fire wall at all...
Spectra is what I see Jo daddy used on his builds and I guess he got them from MU.
I bought Spectra 1 piece units too and separated them. They did fit better than a Dynacorn set I also had here. My drivers side went in with minimal grinding but the passenger side required some cutting, metal removal and re-welding to fit the passenger side. If you own a welder and a grinder you can make these fit. No need to use a sledge hammer or a jack to force them in place, they can be made to fit. I'll be adding a Spectra set to my friend's 66 this summer.
I bought the 1 piece units from cjpp, I'm assuming the the lower firewall is cut out and the torque box becomes part of it?
What I realized during my installation is from the factory only the outer portion in the wheel well is added to the firewall. The 1 and 2 piece kits are giving you acsection of the toe board. So basically you’re doubling up on the toe board. I thought about just using the outer part but used both as I thought it would make for a more ridged set up. On the toe board part I folded the flange 180* so I wouldn’t have to cut through my toe boards since they were in great shape. Along with no welding inside the car either.
1 - 11 of 11 Posts
