For those of you running hopped up/performance small blocks and have done all the hipo tuneing, what did you end up with for a total advance and at what rpm? Right now I have mine at 38 and it gets there at about 3800 rpms. Just wanted to see where everyone else ended up.
67 mustang coupe
70 mustang mach 1
88 mazda/ford mx-6
To a degree it's really a matter of preference. I run my 351W in my race car with 36 degrees total at 4000 RPMs because that's where my engine makes the most power over a broader range. Your engine may need more or less advance to get the results you are looking for.
Every day is a holiday if you love your job.
Current projects: 65 Fastback, 68 Coupe Oval Track Racer, 64 Galaxie 500 XL, 54 F-100 Pickup
Discussion Starter · #4 ·
Yeah, I know its all in personal preferance tailored to the specific motor, I just wanted to know where everyone else ended up! I am now going to go to the change and testrun and change again methode. KEEP POSTING!
67 mustang coupe
70 mustang mach 1
88 mazda/ford mx-6
15 and 38 degrees, all in at 3,000 RPM. 351W, F303 roller cam (.512" lift, 226 degrees duration at .050" lift), and aluminum heads.
Hope this helps,
Russ
http://albums.photopoint.com/j/View?u=1595962&a=12199293&p=44747301.JPG
Dizzy timing is 24 at 3000rpms set by Performance Distributors based on what I told them about my combo. 12 initial makes 36 total at 3000rpm. I have tried changing initial below that but haven't really noticed any change.
Door handle first when cornering
