1 - 11 of 11 Posts
Do you have to remove the driveshaft in order to pull with a dolley? Can't you just leave it in neutral and be ok?
Years ago, you could leave the driveshaft in with automatic transmissions because they use to use a rear oil pump that would lube the transmission without the engine running.
Now, automatics use only a front pump and will not lube the transmission if the engine is not running.
But as the others have said and I have done, remove the shaft. Even if the trans had a rear pump, the drag will be great and only compound the load during towing.
Maybe I'm just showing my stupidity and all (which is probably the case) but isn't the idea of a dolley so that you don't have to remove the shaft or do anything else of the sort? Or, couldn't you tow it from the rear end, with a steering column lock, and not have to do anything else?
I'm probably wrong, so don't listen to me unless someone else confirms :).
~JP
For a cross country trip ,like you are doing,I would stick with the trailer plan you were originally going to do. I f you do choose the dolly route,front wheels on the dolly with driveshaft pulled and trans plugged ,even on a stick car with this distance.
Dave
Also if you are going cross country, check on the laws for each state. I don't think you can use a dolly on an unregistered car in my state. I don't know your case but if there is some strange law its better to know about it before being stranded.
I also heard the dollys were hard to back up. If you dont have the wheel fixed. I sold a car and it was towed on a dlly. The new oner later told me the worst part of the trip was getting out of a restaurant in town.
Discussion Starter · #11 ·
Thanks all. I have towed with a dolley but was just wondering why. I'll take the safe route and pull it. I just wanted to keep it in so when I get there I can just get in the car and drive it away. Thanks again! ::
1 - 11 of 11 Posts
