1 - 1 of 1 Posts
Are you a collector (hoarder) of parts, and can't resist what looks like a bargain? If you have any of these stashed away for later, and need anything I have right now, let's work a trade. Quality for Quality Only! No Junk,... No B.S.
Most of my parts listed are High Dollar Professionally Restored, or as noted.
I Have:
Restored Parts
- 6K Tach / 120 Speedo w/Trip Combo
- 8K Tach / 140 Trip Speedo Combo 67-68 Restored to Shelby Spec - Built to Order
- 69-70 Shelby 8K / 140 combos Built to Order
- Tach Cluster Housings 67-68-69-70 - Mint!
- Tach Cluster Wiring - Excellent Used or New
- 67 or 68 Under Dash Wiring for Tach Car - Excellent Used
- Quartz Clocks 67-70 - Best Available
New Parts
- 1968 Shelby Console Black/Woodgrain (New In Box)
- Yella Terra (Street Terra) Shaft Roller Rockers Fit 5.0 / 5.8 style heads. (New In Box)
- Yella Terra (Platinum) Shaft Roller Rockers - Primo Rockers! 289/302/351
- Probe Lightweight I Beam Connecting Rods for 347 (5.315)
- Ultradyne Solid Lifter Cam - Over .6 lift (New In Box) 289/302/351 (uses 351 firing order)
Used Parts
- Vent Panels 67-68 Fastback Dark Red - Good Used (No Sliders)
- 69 C-90 351 Heads w/10K (Tanked / Ready For Paint) - Crane Springs For "E" Cam Great Set Of Heads!
- 66 289 Heads (bare) - w/ Screw in Studs
- 69 302 Heads - Clean - Rebuild?
- 67/68 Flat Hood - Good Used
Available Parts currently on my car (have been installed but not driven on, and are like new):
- Edelbrock IAS Front Shocks - Classic Gray
- Poly Spring Perches
- 9 Quart Moroso Custom Oil Pan with Steering Linkage Pass Through - High Dollar Custom!
Looking For as follows to finish my 68 FB restomod or 68 Vert:
- AFR 185's (New or Low Miles)
- Aftermarket In Dash A/C System (ie Vintage Air).
- "Mustang Project" Shelby LED Tail Lights
- New or Nice Used Randall's or TCP Power R&P
- Fays2 or TCP G-Bar
- JMC Hydro Clutch Setup
- Fuel Safe Cell
- Tremec or Z spec T5 trans & Install Parts
- New (or Like New) Super Charger Setup for Vintage Mustang 289/302 with carburation
- Vert Drivers Door Glass (Clear 67/68)
- Tach Cluster Core for Restore 67 - 70
Let me know!
1 - 1 of 1 Posts
