Tranny fluid/grease is leaking from around one of the bolts that holds the entension housing to the gear box.
At first we thought about putting a gasket in b/t the tailshaft and the gear box...however, Mark and Toploader Heaven suggested a gasket prob. won't help much if the leak is coming down the threads and maybe to put some copper silicone on the threads of the leaking bolt. This sounds like a good idea...however I assume I'll have to drain the fluid to get the bolt out and not have fluid come pouring out the bolt hole.
Anyone else run into a similar issue?
Thanks,
Mike
Thanks,
Mike
