1 - 9 of 9 Posts
I have a C4 tranny that when i'm sitting at idle will slip out of gear and i will hit the gas it will just rev until it kicks into gear. Fluid level is good, and i just replaced the filter 2 weeks ago, no pieces or tranny or excessive metal in the bottom of the pan. Anyone have any suggestions or is the tranny blown?
When you replaced the filter did you rember to put the vavle and spring back in, or did they never get noticed??
i never touched them, just dropped older filter out, put new one in and put the pan back on
Ahhh, but the filter holds the vavle and spring in. When you pulled the old filter away from the valve body there was a small valve and spring that fell away in a shower of tranny fluid.
actually, i don't ever think i saw one. I'm fairly new at extensive car work so i really didn't know there was supposed to be one.
Stand corrected, didnt know of the difference. Usually when someone does a filter change and cant get the trans to shift right its the valve and spring.
Sorry for the scare.
Discussion Starter #9
yeah, but it was also shifting poorly before i changed filter. I'm beginnning to think that the tranny is just blown. Though the fluid wasn't burnt or anything like that when i changed it.
1 - 9 of 9 Posts
