1 - 2 of 2 Posts
Hi i need a trans for a 68 mustang, with a 302 and its an automatic...also need a flywheel but I have no idea which one i need. So please give a girl a little help.
You need a small bell "step case-or case fill" C4 that takes a 157 tooth flywheel- thats at least what your car would have originally come with. It should be for a floor shift car as well-lever oposite way around than on a column shift car. The case fill means the filler tube and dipstick pass through the transmission body. Some of the larger bell trannies (used with the bigger flywheels-164 tooth) are pan fill and called "flared case bodies".
1 - 2 of 2 Posts
