I have a 1965 Fastback A code true GT with a 91 T5 and an original 9" rear end
Thanks for any help. As best as I can determine, the 1991 Mustang T5 has the following ratios:
1st. 3.35
2nd 1.99
3rd. 1.33
4th 1.00
5th. 0.68
The tire size is 205/60R15. I measured the circumference at 77 1/2 inches.
The original 9" in this car had a 3.89 ring and pinion. The current rear end has a Richmond Gear 4.11 ring and pinion. The car is a rocket out of the hole but I run out of gears pretty fast. The recommendations I received from RG is:
If you have a 4.11 ratio now you are running 2654 rpm at 70 mph when in od.
Going to a 3.89 ratio you would be running 2518 at 70 and with a 3.50 ratio you would be running 2266 at 70.
It makes me wonder if I have the 91 T5 ratios correct as it seems to have a higher rpm at 70mph.
Any thoughts or recommendations?
1st. 3.35
2nd 1.99
3rd. 1.33
4th 1.00
5th. 0.68
