I was wondering if anyone knew how to or has done a tremec swap behind a FE. Any information would be great, thanks.
Don't take it as the gospel, but if I remember right, the input shaft length on the 390's is the same as small blocks and not that of the 428's and 427's. So I would think that if you use the spacer for the small block on the 390. I think you'll be o.k.. Any body can add any info?
Tom
You can do anything you want to......ONCE!
aka "my 66 coupe"
All big block S/S transmissions are about 5/8" shorter than the small block parts. A 1" spacer is required on a Tremec to an older small block bell housing, I would imagine a 1 5/8" spacer would be required for a Tremec in a 390
Required tools for operating a Vintage Mustang:
1. Duct Tape
2. J.B. Weld
3. B.F.H. (Big Fat Hammer)
4. VINTAGE MUSTANG FORUMS II
View Album Here: http://albums.photopoint.com/j/AlbumIndex?u=1616948&a=12352157
