21 - 35 of 35 Posts
Discussion Starter #22
Yeah, CA headers are nice but since I’m not going to race, a bit of overkill. I have a friend who’s the Charlie Daniels of the TIG welder, I think I could entice him into a custom set for less than that. $6-700 is a little closer to what I’d be willing to spend. Still seems a shame, though.
66, I liked your answer, too.
You cannot beat the FPA stuff. Get them coated to avoid the rust problems
Seriously though, my FPA long tubes are a work of art and clear everything. They should though, since they were designed and developed for my car. If you get raised-port heads, these are for you.
Discussion Starter #25
If you get raised pet heads said:
Kent, I remember you used to be cutting edge with your car, so I have no problem showing my ignorance. “Raised pet heads”? Sounds either really trick or macabre.
I'm trying to come up with something clever here... Fail.
Should be raised-port.
i'm going to chime in anyway..... I have a set of the cheap ebay stainless tri-y's on my car ( 5.0 / t5 / hydraulic clutch ) and they fit perfect with no mods at all. for the price, i'd use them again, might get lucky a second time.
Don’t think you will find a tighter fitting set of headers than FPA. I think @Huskinhano has MAC headers. They are also pretty tight in accordance with his statements here. I’m not familiar with his complete setup though. All I know is what I saw TODAY with mine own eyes.
If money is no object, I wouldn’t think twice...65-66 Mustang, Tri-Y, s.s. stepped, S.B. Ford, std. 289 head bolt pattern, 3'' collector (specify hyd. or mech. clutch)
They check all the boxes and the sound is almost orgasmic.
At that price, ALMOST orgasmic ain't gonna cut it...
Allen
I had to do a double take, now there’s a name from the past. Welcome back
I've had two vehicles with FPA headers on them and they fit perfectly. You get what you pay for and stan is the man.
So, for a street car, are Tri Y's the way to go?
I know everyone swears up and down on the FPA and doug thorleys..
Or you can fall off the deep end and build your own. No crushed tubes, no interference issues, put the tubes wherever you need them or however you want them.
These are equal length , 24" long 1.75" dia. primaries, 12" long 2" dia. secondary's to an oval 3.5" collector out of 316 and 321 stainless tube. The cost isn't as high as Patrick's suggestion, but they take a little time and effort to put together.
Discussion Starter #35
Impressive work
Unfortunately my welding skills would likely produce something closer to a first grade science project. But, I see you are in NC.......need to practice on a set of Tri-ys???
21 - 35 of 35 Posts
