I ran across this cool water pump from StewartWarner
It's computer controlled and is plumbed into your radiator hose. It was designed for racing applications, and is universal. There might be some of us looking for an alternate cooling solution. I'm not quite sure what you'd do with the existing pump. Maybe remove the innards, plug where the shaft goes, and use it to direct coolant thru the L/R side of the block? For those of us running an electric fan and a thick radiator in need of extra space, this might be a solution, in that you could completely do away with the water pump pulley AND shaft...
http://www.emp-corp.com/Images/Key_Products/_key_computer_controller_pump.gif
