Still trying to position the vinyl top sail panel trim before I drill the quarters. Could someone please post or send a photo of where the sail panel trim meets the back window molding. I can't tell if the tips are even or if the sail panel trim is shifted forward a little. A measurement at the tips might work. Car has been a part for twentyfive years, way longer than memory. Thanks
Sorry I don't have the measurements anymore (sold my 66 & 67 with vinyl tops)but what I did when it came time to drill the holes for molding was make a paper/cardboard template of the molding ( and affix it to car. The holes are drilled larger than the studs so there is some room for adjustment.
I have an extra set of trim that I removed the studs from and drilled to use as templates but I can't quite make up my mind as to where to position them. Thanks
