Trunk mount Battery Q's
698 Views 2 Replies 1 Participant Last post by  Opentracker
I am considering moving my battery to the trunk. I know mounting the battery box is pretty straight forward. My question involves exactly how to get the cable from the trunk to the solenoid. I'm pretty sure I want to run it under the car. I don't like the idea of running a hot cable under my carpet. I am wondering specifically about how to attach the cable to the underside of the car. Do I go to a hardware store and get some small conduit clamps or what. Its a fairly big cable and I want it to be plenty secure. I'm also wondering where the best place is in the back to run the ground cable to.
Pat, I am obviously looking in your direction, :)
Any thoughts or suggestions would be, as always, greatly appreciated.
Thanks Again
· Supporting Vendor
There are a couple of ways to go. My '65 has the battery and starter sol. in the trunk.
The big fat cable running to the front is only hot while the starter is getting juice. I never
liked the idea of having the cable coming from the trunk hot all the time.
If you must, you can put the cable in a metal sheath. The flexible metal conduit that
house electricians use makes a great protective cover for your batt. cable.
Moving the sol. into the trunk is easy. Run the two small wires from the front for the
sol. and a larger wire for the acc. which is the same large wire that goes to the alt.
Use a fuse link for the acc. wire. Use a regular batt. cable from the batt. to the sol.
and the big fat cable goes from the sol. to the starter. Really cleans up the engine
compartment too.
· Supporting Vendor
compartment too. Run the ground cable to a bumper bolt. You can secure the cable
with rubber insulated clamps from the parts store.
