Hello. Thinking about putting the battery in the trunk so I have a nice place to put the MSD box. Here are my questions...
1. If the trunk is sealed off from passenger compartment (by aluminum sheet covering package tray, taking place of interior quarter panels and cardboard divider), would I need a sealed battery box?
2. Where can I route the positive battery cable. Since I figured 2 gauge cable would fit under the sill plates (it does), that is where I'm routing it. Now, would it be better to route the cable inside the engine compartment or outside along the fender aprons? Would it be good to protect with cable with added insulation?
3. Where do I put the solenoid. I figure that having 15 feet of hot 2 gauge cable running the length of the car, looking for the easiest path to ground isn't a great thing. If I put the solenoid in the trunk, then a wire still has to be routed for the MSD box (10 gauge). If I leave the Solenoid in its stock location, then I have less wiring work to do, and I can simply use a bulkhead connector to connect all the ignition components and the solenoid together. Is relocating the solenoid worth the effort?
I have done searches about relocating the battery on this forum (lots of info about it) but everytime I thought I had all of the answers, I found more questions. I have a basic idea of what I want to do, but maybe someone out there can offer me a solution or give me some advice I overlooked. THANKS IN ADVANCE!!!
Danny
Danny
