1 - 10 of 10 Posts
I have a 66 stang and am dropping in an 8" rear. It is an I6 but is being tricked out a bit with the aussie head, new holley carb, headers, etc. It should put out around 200+ horses. I was wondering if I should go as low as 3.80 gears. I originally thought 3.55 would be ideal but have heard others saying that 3.80 would be ideal. I don't plan on doing very much highway driving but I will be doing some. Also, the unit I am looking at is Posi and I was wondering if this will get you a but more go off the line as well? Will the added traction make any difference in pickup?
Tim
I'm currently installing a 3:00 traction-loc as I wanted the car to be friendly in the highway. 60 MPH will be about 2600 RPM with automatic, 3:25 @ 60MPH will be around 3300 RPM. All this is also affected by your final drive in tranny.
Having the limited slip rear will help you off the line if traction is a problem. With the stright 6 it might or might not be an issue. The 6's do have a lot of torque...so I'm guessing it will help.
Regarding the gear ratio...I have 3.55s. Personnally, I wouldn't even want 3.55's if I didn't have overdrive. I'd go with 3.25's. You don't want 3.80's.
Phil
I have 3.80 and there is no way I would consider using it for any type of highway driving unless I was to switch over to an AOD tranny.
Well I guess I should have mentioned that I am installing a T5 tranny from an 87 mustang with overdrive.
I just returned from a nearly 6000 mile road trip with 3.50's on a 3-spd stick (1:1 in top), and I can tell you it's very liveable. We cruised at 70-75 mph all day. With an O.D. top, I'd go even lower. That is, 3:80's would be no problem. Now whether 3:80's would make your first gear a useless granny gear, I don't know.
Posi will not cut your E.T.'s with a 200 hp six. It will avoid embarassing one-wheel burnouts, though.
One other thing that I have discovered is that traction bars are a necessity if you want to do any clutch dumps. I had to break a spring mount off the axle housing to find that out. ::
7
Ernie, I have 3.25 gears and by math and tach it turns about 2650 @ 60mph
if your going to be running a T5, i think you can get away with the 3.80's if you dont mind spinning some rpm on the freeway.
i'l tell you though, i run 3.55's with my c4, and i HATE it on the freeway, i avoid it with a passion. especially seeing as how here in the bay area if your going 75 your getting run off the road !
I just installed a set of 3.80's this weekend with my C4. but I am also running a 3000 rpm stall and need to keep the rpm's up while on the highway. I have a set of 2.70's i just yanked out of the 8"-er iy ya want those!! ::
1 - 10 of 10 Posts
