Your 22 degrees of advance sounds a whole lot better than your being 10 degrees retarded and getting the bog. It's not unusual to run over 30 degrees of Total advance. Yes, it can cause you engine to overheat, but I don't think that is the reason it died. Perhaps you need to back it down a little. What does you temperature gauge show? Being to retarded can cause you to overheat too.. good luck!
See my 69 convertible and the VMF parking lot at: http://www.geocities.com/Bishir1/FrontPage.html
http://www.jps.net/binay/webdocs/frontside_sig01.JPG
